200-4R Shifting Problem! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2010, 05:48 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
I've got a 200-4R behind my Hemi, and I'm having a BIG problem trying to get it to shift properly. I've tried adjusting the cable housing back and forth, and the cable itself back and forth with out much result. I have it at the point now where if I press down moderately on the accelerator, it shifts 1-2-3-4 okay, but if I push down lightly, it doesn't shift under 2,500-3,500 RPM, and downshifts by itself when I slow down to 1,500 RPM. I'm wondering if I have a governor problem. The TV cable, accelerator/TV cable mount, and throttle linkage adapter kit all came from Bowtie Overdrives, and have been installed correctly...
Old 06-15-2010, 11:18 AM
345 desoto's Avatar
Got the answer to the problem http://www.chevyasylum.com/tech/tvcable.html. Cured it completely. Transmission upshifts, and downshift beautifully...
68 Mustang 200 6cyl Stall Problem jmacs53Willys Engine 26 11-16-2008 07:20 PM
Weird shifting problem 2002 Impala 406chevelle Transmission - Rearend 6 02-02-2006 01:04 PM
TH350 Warm Shifting Problem thurr Transmission - Rearend 4 11-08-2004 01:01 PM
700R4 Shifting Problem mann1961 Transmission - Rearend 2 06-12-2004 02:39 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 06:18 PM
