On the right rear of my 200-4r trans, there is a small round boss near the output shaft, and a rivet, but no tag. Assume that boss and rivet is where the ID tag went.
But, on the left side of the trans case, just above the pan flange, there is a boss with the numbers 6G9735062 stamped into the case.
is this some sort of VIN derivative? Does the 6G mean anything?
No clue what that number is, but you could try pulling the pan an see if there is a number on the valve body, that might help narrow it down.
For example I got my 200-4r trans from an 87 monte SS for the V8 Beetle I'm building, and when I pulled the pan the valve body was a CZ-5 valve body which is I believe 86-87 monte ss.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
