200 4r Temperture - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2009, 04:14 PM
200 4r Temperture
What range should the trans. fluid temperture on a 200 4r run?
Old 03-26-2009, 10:36 AM
SSedan64's Avatar
Trans Temps
Trans Temps
http://www.tciauto.com/Products/Tech...expectancy.asp
Old 03-26-2009, 10:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you use an engine radiator OEM type set up the trans fluid will be that of the water temperature when up to full operating temp.
So, the cooler the engine temp, the cooler the trans temp.
This is one reason why so many performance and heavy duty/towing vehicles use auxiliary coolers. Plumbed after the radiator, BTW.
Like engine oil, the fluid has to reach a high enough temp to evaporate moisture, etc,. but not so high as to damage the fluid.
Bottom line 180 degrees F would be about the practical ideal- hot enough to rid the fluid of contaminates yet cool enough for long fluid life.
Old 03-26-2009, 11:04 AM
Thanks for the replies. The TCI chart was great info.
200 4r 1st to 2nd shift Ted's37 Transmission - Rearend 7 11-26-2008 10:55 PM
200 4r Converter Lock Up Ted's37 Transmission - Rearend 8 10-03-2008 09:53 AM
Need advice on 200 4r mods bnewsom Transmission - Rearend 4 02-03-2006 03:23 PM
information 200 4r turbo 350 700r4 william64 Transmission - Rearend 3 01-29-2006 07:47 PM
200 4r torque converter help...... isleofwight Transmission - Rearend 3 07-05-2004 01:42 PM
