200 4R Torque Converter Lock Up Circuit - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2009, 11:54 AM
200 4R Torque Coverter Lock Up Circuit
I proof read this write up a number of times, but I just saw that I had some wrong pin numbers on the TDR. Pin 5 should be pin 12, and pin 4 should be pin 8. I will correct the document and reload it. If any of the monitors read this, please pull this post until I get the correct write up posted.
I am sorry about the error.
Attached is a write up, and schematic on how I delayed my lock up. I am posting this responce because there has been some recent threads on this subject. Using this delay cercuit has worked great on my 37 Ford with a SBC and 200 4R tranny. Listed below are the links for the Relay and TCI Kit.
http://catalog.idec.com/productserve...%2D4SN6D12&FAM
http://www.summitracing.com/parts/TCI-376600/
File Type: doc 200 4R Torque Converter Delayed Lock up Circuit2.doc (135.0 KB, 261 views)
200 4r 1st to 2nd shift Ted's37 Transmission - Rearend 7 11-26-2008 10:55 PM
200 4r Converter Lock Up Ted's37 Transmission - Rearend 8 10-03-2008 09:53 AM
Diagnosing lock up torque converter inoperation junkyardjeff Transmission - Rearend 0 07-04-2006 06:35 PM
information 200 4r turbo 350 700r4 william64 Transmission - Rearend 3 01-29-2006 07:47 PM
200 4r torque converter help...... isleofwight Transmission - Rearend 3 07-05-2004 01:42 PM
