200-4r trans question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2007, 07:38 PM
75sprintguy's Avatar
Last journal entry: a good used 350 we installed
me and a buddy put a olds 350 and a 200-4r in my 79 malibu i noticed the trans had an electical plug or some kind of wires plugged in it on the side
of the trans whats it for does anybody know that might help me
thanks
Old 09-14-2007, 07:54 PM
jakeshoe's Avatar
Those wires are for the lockup converter, and you need to hook it up.
You can get the pigtail from GM to hook up to the case, several ways to make it work but I use a normally open pressure switch in the 4th gear circuit on the valve body, ground the TCC sol to the switch, and run a 12V IGN supply through a vacuum switch to the trans.
Old 09-14-2007, 08:11 PM
what will be the result if i dont
Old 09-14-2007, 09:43 PM
jakeshoe's Avatar
Reduced lube to the trans, burned up transmission.
Old 09-16-2007, 08:00 AM
Hey Joeshoe
Hate to jump in on someones post. But I finished my 2004r and will be putting it in soon. Thanks for all your help..
76 Trans Am Transmission question... jdauel Transmission - Rearend 2 04-14-2006 04:54 PM
Chevy Trans. Question whynot Transmission - Rearend 5 02-21-2006 07:57 PM
Question / Power glide trans W/OD ??? 1939P7 Transmission - Rearend 14 02-19-2006 02:37 PM
want to change from 200 to 700 trans. lanierledford Transmission - Rearend 2 08-26-2003 08:25 PM
I have an 1986 firebird trans am, quick question Nightrider86 Body - Exterior 1 12-08-2002 09:31 PM
