200-4r trouble help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2005, 06:43 PM
406 ss monte's Avatar
eat a beaver, save a tree
I just put another 200-4r together. i used a ss Monte Carlo case, valve body, servo, & governor with an alto red eagle wide band, new clutches & steels, & a new thrust washer set. It works good, but second gear doesn't shift firm like it should. It slides into second from first. When I put the servo together, the smaller lip seal didn't seem like it was big enough, & the next larger seal was to big for the piston. I'm thinking the seal is to small & isn't engaging like it should. The only other thing I noticed was the wider band seemed a little tighter than a normal band. Could the servo pin be to long? How can I tell if the pin is to long? Other than a spongy 1-2 shift it works perfectly. Any help would be much apreceated. Thanks again
Old 03-13-2005, 09:55 PM
200 4r
ive gota 200 and it shifts pretty hard with a b&m shift kit. try playing with your tv cable. theres a certain way to do it i think this url will help tv cable adjustment
Old 03-13-2005, 09:57 PM
200 4r
try this site too http://www.chevyhiperformance.com/techarticles/83878/
Old 03-15-2005, 12:53 AM
the tv cable is perfectly set. it's starting to shift harder. i think the band just needs to be broken in. thanks for the replies, the tv cable was the first thing i checked.
Kids and trouble Kevin45 Hotrodders' Lounge 15 02-20-2006 04:27 PM
200 4r torque converter help...... isleofwight Transmission - Rearend 3 07-05-2004 01:42 PM
Trouble codes from getting rid of the 4L80E, how to fix? Jason Transmission - Rearend 3 07-15-2003 09:21 PM
THM 200, CBC 350 or TH 350???? 78novaman Transmission - Rearend 4 11-25-2002 02:34 PM
c4 transmission trouble Steve W Transmission - Rearend 2 11-04-2001 07:04 PM
