200-4r TV lever arm / bracket assembly - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2012, 09:04 PM
I have the same problem as the original post with the pin and spring, can anyone post a picture so we can see the right way to install this piece please?
Old 11-19-2012, 05:13 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders
You posted to a 8+ year old thread.
I moved your post to a new thread for some answers.
Please give the membership some information on your engine application
Old 11-19-2012, 11:18 AM
I was installing the TV made Easy kit, and when I removed the TV lever assembly the small pin with a spring over it came out and I can't seem to find any information about how it goes. I could really use a picture of the assembly or some diagrams because it keeps popping out the way I'm doing it.
Old 11-19-2012, 06:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there are extensive instructions on Bowtie Overdrives web site on the TV Made EZ device
Old 11-21-2012, 02:05 AM
SSedan64's Avatar
2004R TV exhaust linkage lever
If you're referring to the TV exhaust linkage lever & spring down on the Valvebody this will help.
before installing. | Page 3 | TurboBuick.Com
Also a Pic at bottom of Pg. 2
inner downshift lever and inner manual lever. C6 ekacpuc Transmission - Rearend 1 12-28-2011 08:38 PM
head assembly Q, more like dis-assembly bullheimer Engine 5 11-27-2007 04:48 AM
Convert multi-function signal lever to plain lever? murrsue General Rodding Tech 0 03-07-2005 07:56 PM
2004R TV Lever Arm and Bracket Assembly Question Ghetto Jet Transmission - Rearend 11 11-30-2004 08:40 AM
200-R-4 VALVE BODY ASSEMBLY GRANDNATIONAL6 Transmission - Rearend 2 05-08-2003 03:22 AM
