#1
200 I6 to 300 I6
I would like to put a 300 I6 in my '67 Falcon which currently has a 200 I6. What do I have to do to put it in?, I'v heard it is a bolt in but want to make shure b4 I purchase a motor.
| Sponsored Links |
Register now (free) or login to remove ads |
#2
Pretty sure that the belhousings are a different pattern. The 300 has` the same pattern as a 302, I think.
#3
I dont have any experience with em but it's cool to see somebody building something different. YAY!
#4
I have heard that the 289/ 302 had the same pattern as the small 6's. I got a cruisomatic 3spd auto ( I think it's short name is C3 ). Are the motor mounts the same? |
#5
my grandpa had a 63 falcon 2dr hard top with a 300ci in it..made his own intake and header..roller cam ..crazy thing ran 11;s.. they make a ton of tq...the 200 ci motors are a lot different...the 300 has the same bolt patteren as a 302 ford..the 200;s do not...
#6
I agree
Yeah, I agree. There was a guy in Saskatoon, Saskatchewan who used to run a 300 inline six around 1980 or so. He had sectioned some 351 Cleveland 4V heads and had them welded back up. Apparently all of the bolt-holes and coolant passages, etc all line right up. Ford's BOSS 300? I think he named the car "Scrapper II" ... are there any other old Saskatchewanians in the group that remember that car? That car was just crazy! I don't recall his times, but it was fast and consistant too. Welcome to the group Matt. It's nice to see a young fellow with these interests. Don |
#8
Dude, you best measure that 300 first. Ive stuffed a FE in a 67 b4, I dont think a 300 gonna fit. A 250 outta a Mavwreck or fairmont will fit. BTW got a 4 bdl manifold for that 300 if ya fit it in. |
#9
#10
300 is awful tall and long for that engine compartment, would take a lot of modification. I also think the bolt pattern is different.
If the automatic is original cruise-o-matic for that vehicle, it is probably an FX, I think small block V8 bolt pattern would fit but check with an expert like Kultulz or in the reference sites (can't find them right now -- but may be able to check later). Don't want to discourage the 300, it is a great engine, but just be aware it will be a challenge..... |
#11
That's exactly what I was going to say. Those guys are the experts. |
#12
200 to 300
Something you might consider, is swapping a 250 Ford I-6 into your car. It is basically the same engine as your 200, with the exception of a slightly taller deck height and it also uses the 6 bolt SBF bell housing. Engine mounts are the same oh the 200 and 250.
While you would be giving up 50 cubes by going with the 250, you are also giving up about 100 or so lbs of weight. The 250, is an undersquare engine, with a realistic max rpm range around 6000 RPM, for street use, but it is capable of putting out a bucketful of power up to that point. As for speed goodies, I believe Offenhouser still makes the 3 single throat carb intake, for them, which is utilized by drilling two holes in the intake runner, under the carb pads on the intake setup. You might also consider checking with Clifford Performance on cams and headers, as I know he does have them for the Falcon 6, as we used to call it. Using the 300 will require fabricating or modifying engine mounts from a car or truck that once contained either a 240 or 300 I-6. The 240/300 do use the same 6 bolt bellhousing as used with the 289/302. One of the major problems you will run into with this swap is the oil pan. Having helped drop a 300 into a 69 Mustang, one time, I know what a pain that is. I dont remember exactly what the guy did about the pan, whether he did his own fabrication or had one made. You will also need to scavange accessory mounting brackets from a car or pickup that had the big 6 in it. The Cruisomatic transmission is also known as the FMX, which has an iron center section with an aluminum bellhousing and tailshaft housing. Swapping bell housings is a simple matter on both the FMX and the C-4 since both bolt to the front of the transmission. You may well also have the C-3 transmission, which is a light weight version of the C-4 and may well not stand up to the power put to it by a larger engine. If the C-3 is what you have, best to junk it and put in a better trans. The C-3 and C-4 are both all aluminum housed transmissions. Last edited by Max Keith : 08-09-2005 at 11:00 AM. |
| Thread Tools | Search this Thread |
| Similar Threads for: "200 I6 to 300 I6" | ||||
| Got this carb in trade, only 300 miles on it.... he says. | killerformula | Hotrodders' Lounge | 7 | 10-19-2004 05:42 PM |
| Info on Ford 300 I6... | Mike_82 | Engine | 5 | 07-05-2004 03:32 AM |
| reaching the great 300 mark | camino_man | Engine | 5 | 05-14-2003 03:33 PM |
| THM 200, CBC 350 or TH 350???? | 78novaman | Transmission - Rearend | 4 | 11-25-2002 03:34 PM |
| 66 ford truck swapping a 240 i6 out for small block chevy | igotachevyor2 | Engine | 0 | 04-14-2002 04:19 PM |
