200-R-4 VALVE BODY ASSEMBLY - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2003, 04:41 PM
Post 200-R-4 VALVE BODY ASSEMBLY
MY 200-R-4 TRANS HAS A 4 PIN LOCK-OUT VALVE BODY ASSEMBLY. CAN THIS VALVE BODY ASSEMBLY BE PUT INTO ANY 200-R-4 TRANSMISSION THAT HAS A 3 PIN LOCK OUT VALVE BODY,AND WORK?
Old 05-07-2003, 07:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
Not sure what you mean about a 4 or 3 pin lock out valve body.
To swap plates and valve bodies around there are a couple of holes that need to be matched up. Depends on if there is a converter clutch shift valve in the valve body or not.
This would require photos to indicate which is where.
Old 05-08-2003, 03:22 AM
airworld2's Avatar
Post
Yep ,Crosley's right spacer plate and valve body need to match for lock up valve. I think your looking at early style with 3 wire connector, had to pull out an old book forgot they had so many wire connector, I've only seen 3 out of 12 they show in my book.
airworld2
