Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 200-R-4 VALVE BODY ASSEMBLY
Old 05-07-2003, 08:21 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Cool
Not sure what you mean about a 4 or 3 pin lock out valve body.
To swap plates and valve bodies around there are a couple of holes that need to be matched up. Depends on if there is a converter clutch shift valve in the valve body or not.
This would require photos to indicate which is where.
