200 R4 can I build it myself? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 12:29 PM
msc66's Avatar
Last journal entry: pics
Cam bearing failure has taken the $ I had saved for my 200 r4 build so my question for the experts is do you think I can build it myself?
I've built many motors and a few rear ends but never an auto trans. If I get all the parts from someone like CPT and a book or video, can a fairly competent home mechanic like myself pull it off?
Old 02-01-2009, 04:02 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
I looked at doing a 700-R4 myself and, while the process is straightforward, there are a few special tools that need to be used. I have seen a few home-made versions of these tools, so it is possible to make them and do the job yourself.
Still, I made the decision to pay roughly $2K for a pro to do it because 1) the transmission was damaged to begin with and 2) it would take a lot of time to fabricate the tools and do the work.
While I paid $$, I now have a transmission that was re-built and inspected by a professional who's done hundreds of these (he's also the local Allison Transmission authorized repair shop) and carries a warranty. Automatic transmissions and A/C compressors are the last two car parts that I have not tried to re-build.
Old 02-01-2009, 05:56 PM
SSedan64's Avatar
It can be done. You don't need a lot of special tools but, I would recommend 2, a Low/Reverse Clutch Removal/Install Tool and a Clutch Spring Compressor.
An ATSG Manual & GM Principles of Operation Manual is very useful too. CKPerformance sells a 200pg. Tech Manual that shows all the tips for modifying/upgrading, building etc..
http://www.ckperformance.com/resourc...4RCATALOG.html
http://www.ckperformance.com/resourc...CALMANUAL.html
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
do it right the 1st time, strong 400 short block budget build, stock parts? Warrant Engine 9 12-04-2006 08:29 PM
350 build up opinions? Artemis Entreri Engine 17 08-09-2006 02:48 PM
200 L6 3.3L Mustang 65Stanger Engine 6 07-11-2006 09:24 PM
Strange 200 R4 troubles joeyg329 Transmission - Rearend 3 12-11-2003 07:33 PM
