2000-2006 Lincoln LS irs swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2011, 04:24 PM
Mutt's37Buick's Avatar
I've seen several sites and even kits for swapping a Lincoln Mark VIII irs into a car or truck.
1) Has anyone swapped a Lincoln LS irs into a street rod.
2) Pictures and wheel track look very similar between the Mark VIII & LS IRS. Does anyone know if the LS rear can be easily swapped?
3) If so, are the mount points the same?
Thanks
Old 08-01-2011, 07:44 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Clutter
I've read that the LS rear end (and new T-birds) is a Jaguar item.
Old 08-02-2011, 08:38 AM
Thanks for the response. I received similar info as well. Looking at the specs, the engine size is also offered on the Jag S-type of the same years.
I believe the entire drive train and suspension are all Jag. This is dissapointing because I wanted to use a Crown Vic suspension in front and would prefer Ford rear as well. Reliability looks good, but I'll have to check more into the difficulty of installation on the LS rear suspension.
Thanks
engine swap in 94-2000 camaro menoaz Hotrodding Basics 1 07-10-2011 05:01 AM
2006 chrysler 2.4L no spark after engine swap fast68 Engine 0 10-10-2009 01:25 PM
2000 Lincoln Continental trans shift problems mbooom1 Transmission - Rearend 1 11-28-2008 04:19 PM
Tapping into dome light circuitry 2006 Lincoln Mountaineer Rambo_The_Dog Electrical 6 06-27-2007 07:39 AM
2000 dash swap in 90 chevy Sudden Psycho 31 Interior 4 05-04-2004 09:39 AM
