2000 Buick tranny shifting weird? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2006, 03:53 PM
frankenvette's Avatar
Go ahead kid squeeze the wheez
I drive a 2000 Buick Century, 3.1l engine and it has developed a shift that is somewhat similar to a nasty shift kit. The shifting is accompanied by a whining noise, that builds as the rpm's build, then subside with each gear change. This thing shifts with a solid clunk! I have noticed when the tranny starts acting up, the temp gauge is higher than normal. Took the temperature off the hose at the thermostat and got 210*. This is not critical, but the outside temps are only in the 80's, and I'm afraid it may get worse when the heat builds later this summer.
Old 06-13-2006, 04:10 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Just in case you don't look at your original, I'll post a link to this post, which contains a TSB dealing with this problem.
HTH,
Freak
BB Buick in a Pontiac Tork69 Hotrodding Basics 2 02-09-2005 05:44 PM
my buick daddyrain Engine 13 11-16-2004 10:09 PM
Need Help From Olds And Buick Guys fr33zypop Engine 13 10-13-2004 01:39 AM
Buick Century or Buick Skylark 2 7skylark6 Engine 4 12-26-2003 10:05 PM
Buick 455 and an od tranny? wellcontrol Engine 10 10-19-2002 08:19 AM
