2000 chev S-10 truck auto trans shifting problems
Good day.
I have a 2000 chev S-10 4.3 truck. I just bought it. I drove it home and changed the lifters, then wound up taking it apart again and re-replacing the intake and plenum gaskets because the engine revved up high when I started it. All the gaskets were fine. The engine still revs fast. Since that time The transmission does not shift unless I wind out first gear and let off the gas, Then it will shift into second gear.
The truck shifted fine when I drove it home from Middle-burg, when I bought it, about 30 miles. It shifted like a new one. Can you tell me what I did to to make this truck dislike me?
One other thing, after I replaced the intake, the transmission lines were not seated correctly . When I started it, I lost about 2-3 quarts of transmission fluid. I replaced the fluid with the recommended brand Dextron.
