2000 chevy s10 2.2 not shifting - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2011, 06:46 PM
i just replaced shift sensor a.....all gears work manually... but want shift like they are suppose to ,,,it want even change out manully by hand.... what do you think jon...im stressed about this 2000 chevy s10 2.2 l
Old 09-17-2011, 06:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
welcome to Hotrodders.com
I edited the thread title to indicate what vehicle you are working on.
Mileage on the trans? Any recent repair or service work.
Does the speed-O function?
Do you have reverse gear?
Old 09-17-2011, 07:00 PM
all gears work they just want change automaticlly....yes have reverse...what is speed 0....rebuilt about 3 years ago
Old 09-17-2011, 07:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Speed-O is that little gauge that indicates road speed.
Is the check engine lite illuminated?
Old 09-17-2011, 07:06 PM
speed o works hooked up to computer...po571 came up fixed that same ****yes engine light is on
Old 09-17-2011, 08:32 PM
transmission...
dropped pan changed filter fluid shift sesors....put on computer code came up shift solinoid adone that 80.ooo miles but truck is babied.....im baffeled now and could use help...you can take off in all gears....reverse works speedometer works....it auto matic but just want shift at allcan any one give me some fresh ideas...please help....2000 chevy s10 2.2 l im new on here just trying to get advice....would really appriciate it....thanks
Old 09-17-2011, 08:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Charles , Please stop creating new threads for the same question.
I merged your recent post to this thread and dumped your double posts
Post your additional information in this thread so the members can see the complete discussion in the same thread
Old 09-17-2011, 08:38 PM
sorry....
new to this just trying to get help my friend
Old 09-17-2011, 08:53 PM
pcm
where is this located...at
Old 09-18-2011, 07:52 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Charles, you indicate the shift solenoids (2) were replaced.
The check engine is 'on' , now? Were the codes cleared out and they come back immediately and the check engine lite comes back on?
It would be a good idea to drive the truck with a proper scanner hooked up to view the live data stream. You watch for the PCM to see if it is commanding a shift or not. You can also test the trans manually with the scanner to see if it shifts as you manually tell it to. The live data stream also shows other sensor operations that affect the vehicle operation.
The speed-O functions per your post. In the dash, does the PRND321 indicator function correctly too?
It is also possible you damaged the wire harness when changing the shift solenoids. Often the clearance for pan removal is tight with the exhaust in the way on some vehicles. The connectors can break and your truck is 11 years old, unless the internal wire harness was replaced during the rebuild you mention.
Old 09-18-2011, 12:47 PM
tranny
i drpped the pan today and put a test light on both sensor connectors...they have power there....also reset everything with computer....even undone the battery cable.....stil want shift but light stayed off....hooked back up tp computer....says shift sensor is stuck....just like before....any ideas before i go crazy.....lol
2000 Chevy S10 shifting trouble adicus Transmission - Rearend 12 09-15-2011 07:24 PM
2000 Chevy S10 shifting trouble Mike22 Transmission - Rearend 6 01-02-2009 06:30 PM
2000 Jimmy with shifting problem (code P0753) rjdrw Transmission - Rearend 4 12-27-2006 05:47 AM
2000 Buick tranny shifting weird? frankenvette Engine 6 06-13-2006 07:28 PM
2000 Buick tranny shifting weird? frankenvette Transmission - Rearend 1 06-13-2006 04:10 PM
