2000 GMC sluggish on hot restart - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
  #16 (permalink)
Old 11-13-2013, 01:31 PM
Rhansen's Avatar
Footbraker
It doesn't seem to matter whether it sits for a few minutes or if I restart it immediately, it still acts weird on hot restarts - but only for a short time...
No funny noises/lifter clack (even with the doghouse off). Has 40 psi of oil pressure at a hot idle if the gauge is to be believed.
The fuel trim readings were not from when the truck was acting up, first on my list were fuel pressure, O2 sensors, MAF and coolant temp. sensor. Looked at fuel trims as an afterthought....
Another possibility is that the new 'spider' is leaking (bad out of the box??)
Changed the plugs, all had a dark "stripe" that I am assuming is where they lined up with the intake valve.
top left is #1, bottom right is #8
cap & rotor
  #17 (permalink)
Old 11-14-2013, 11:44 AM
I cant see the contacts between the rotor and the cap, but does that contact between the rotor and the center coil feed button look blackened?
I'm wondering if we have a coil issue here.
3 Winters ago, one my 97 ecab 2wd L31, the truck would feel as though it wasnt getting enough fuel. Fuel pressure, poppets, fuel filter all checked out.
I was getting desperate. I took the coil off of my 97 rcsb and tossed it on the 97 ecsb and Voila, no more issue.
GM p/n for an OEM Delco coil is 10489421 and its $42.00 from Rock Auto as is GM PArts Directs price.
Aitex is $38
Delphi is $36
Ultrapower is $21
I would go with a Delco and all OEM parts ESP. for ignition parts. These 1996-2003 Vortec 4.3,305,350 and 454 all use teh same basic coil setup. It is extremely hot compared to older coils. In fact its the same coil as used in the LT1/LT4. There is a reason that GM went Coil Near Plug.
This is frustrating. No codes or pending, new plugs a year ago, CSFI poppets to MPFI mini-injector conversion done.
The more and more I think about it, I'm thinking coil.
When it acts up, what does it do if you hold the throttle to theboards?
peace
Hog
  #18 (permalink)
Old 11-14-2013, 10:14 PM
looks like 4 plugs are on the rich side,,, theres signs of fouled plugs,,,,, I would look into coil,,, coil would also do this once the engine is warmed up,,,,had a truck that would misfire when its hot and it was the coil acting up when it was hot,,, so I would check ohm resistance when coil is cold and then once its hot, ,,,
  #19 (permalink)
Old 11-18-2013, 07:01 AM
Rhansen's Avatar
Footbraker
I thought the contact looked normal, more of a smudge than blackened.
If I hold the throttle to the floor (when it's acting up) the misfire becomes more pronounced, the problem will persist longer than if you just use light throttle, and it will pop/sputter a little out of the exhaust.
hard to tell from a pic (plus that pic is kind of dark) but the plugs were very uniform. Look at #'s 3, 5, and 7 and imagine you are rotating the plug. They're all dark on one side, light on the other. They looked rich to me too but never seen it just on half the plug before...
Will have to pull some of the new ones out later in the week (have to go out of town for a few days) and see if they look similar.
  #20 (permalink)
Old 11-23-2013, 06:24 AM
i didnt read all the posts so forgive me if youve covered this but, if you can take a snapshot of ALL the data(while acting up) and upload it on here so we can see whats happening i feel we could come to a better conclusion. it seems by your discription it's happening while it's still in open loop. what's your coolant temp at while it's happening(on the scanner, not the dash) i've replaced a bunch of o2 on these things that hang lean and cause it to run rich or vice versa. what happens if your reset all the adaptives? will it run normal for a while untill it re-learns some bad info?
  #21 (permalink)
Old 10-03-2014, 03:12 PM
Rhansen's Avatar
Footbraker
So 5k miles later the van starts running more poorly, won't rev cleanly in park/neutral and has a definite flat spot at tip in. Still no DTC codes.
Had the bright idea to unplug the MAF and it starts running better immediately so I cleaned it and the van ran well for about 10 mins then back to being a slug.
One new MAF later and voila, problem solved.
Recent Modern Electronic Engines posts with photos
2000 gmc 4x4 novakidd 63 Hotrodding Basics 4 01-28-2007 05:55 PM
2000 GMC shifts rough 85CHEVY Transmission - Rearend 1 08-16-2005 11:52 AM
Hot restart problems willowbilly3 Engine 7 06-19-2005 08:46 AM
Fuel gauge on my 2000 GMC Maverick General Rodding Tech 1 03-05-2004 10:44 PM
Headers on 2000 GMC Maverick Engine 3 09-21-2003 08:10 PM
