2000 grand prix question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2004, 07:54 AM
astrops's Avatar
I have changed the oil in my grand prix, however the computer screen on the dash still tells me that my oil life is low. Can someone tell me how to reset this. thanks
Old 05-09-2004, 09:14 AM
84_sportcoupe's Avatar
If it rolls, I can wreck it!!!
unplug the negative lead from your battery for 10 min then go plug it back in.
Old 05-09-2004, 02:17 PM
astrops's Avatar
thanks sportcoup,
how do the gm guys do it without erasing all of my radio stations though?
Old 05-09-2004, 02:19 PM
malc's Avatar
Living At The Speed Of Life
Take the fuse out for the computer
Old 05-09-2004, 02:38 PM
Iroc'o's Avatar
Ernie not Bert
On my work truck (2002 GMC) he does it through the ignition key I think, some combination of on/off without starting gets rid it.Sorry I don't know the combo.
Old 05-09-2004, 03:12 PM
29 2dr sedan's Avatar
New Member
most shops use a scan tool that plugs into "ALDL" then they can clear all the codes in the computers memory when needed.
Old 05-09-2004, 08:45 PM
astrops,
Check out www.clubgp.com if you haven't already. I have a friend that is a regular on that site and it sounds like there is a lot of good info concerning Grand Prix's on there. Good luck!
Old 05-09-2004, 11:27 PM
check, that works too. its ghetto as hell but i wont tell you i havn't done it
Old 05-10-2004, 12:40 AM
malc's Avatar
What do you mean "ghetto" IT IS the way to DO IT.
Or are "ghetto" and "pimpin" new technical terms?
Old 05-10-2004, 05:41 AM
Wrencher's Avatar
Are you talking about" low oil level, or due oil change" your pm is changed at the screen, maybe your oil level sensor is dirty?
Old 05-10-2004, 08:25 AM
malc's Avatar
Until the computer is disconnected, fuse or neg terminal, it will retain the change oil reminder. The computer does not "know" the oil has been changed and there is nothing to tell it.
He said his "oil life was low" not the level of the oil.
Old 05-10-2004, 03:06 PM
astrops's Avatar
Thanks for the help guys.
Old 02-10-2012, 04:43 PM
ok it tells u in the car Manuel you have to turn the key three times then while the key is on pat the gas pedal 3 times whit in 5 seconds this is what happens with my grand prix
Old 02-10-2012, 05:01 PM
LATECH's Avatar
Lots of real bad info here, anthony 600 is the only one who got it close to right.
IIRC it is also in your OWNERS MANUAL.
Turn on the key and before 5 seconds passes, floor the accelerator 3 times and let off. Then turn the key of, then start car to check.
Now that my not be correct for a GM with an oil life index, but It works on most GM junk, so try it first.
Old 02-10-2012, 10:57 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
thats how i do it on my '98.
