2000 Impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2005, 08:46 AM
2000 Impala
Well lets see where to start It has been hot here in Ohio and Sunday I decided to charge my air condition So I did that with a re-charge kit that I bought at a local parts place. On Monday no air was blowing from my vents any ideas? I checked the fuses and they all looked good then I got the book out and it said that maybe the passenger compartment filter was clogged so I looked but could not find what that was Thanks for any help Ken
Old 06-28-2005, 09:11 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
It may be possible that the refrigerant leaked back out over night, seen it happen many times. Does the A/C compressor come on when A/C is turned on? Here is the location of the in cabin air filter.
Steve
Old 06-28-2005, 09:41 AM
2000 Impala
Thanks Steve for the quick response Yes the compressor comes on and the blower comes on but it will not come out the vents its like a vacuum hose came off or something Will the leak cause this to happen? Ken
Old 06-28-2005, 09:47 AM
1931 steve's Avatar
Wiki Edits: 4
Where does the air come out from? Vents, defroster, or at the floor? And is the air coming out cold?
Steve
Old 06-28-2005, 09:55 AM
Yes the air is still cold but it is not coming from the vents just the floor and the defrost
Old 06-28-2005, 10:13 AM
1931 steve's Avatar
Wiki Edits: 4
OK that changes things. Does this car have the dual climate controls? Also do you hear a vacuum leak at any time?
Steve
Old 06-28-2005, 11:16 AM
Sorry for the delay Yes it has dual climate control and no I do not hear a leak not but I thought I heard one in the engine compartment when I did the recharge
Old 06-28-2005, 02:16 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
You posted this same question in the Interior forum, and here is the link to my response over there.
http://www.hotrodders.com/showthread...442#post473442
Old 06-29-2005, 08:10 AM
Ok I started to look under the hood again when I got home from work and I found a small black hose that was not attached it is routed around the passanger side of the engine compartment and goes back to the back side of the motor if this helps Thanks Ken
Old 06-29-2005, 08:26 AM
1931 steve's Avatar
Wiki Edits: 4
Can you tell if it is a vacuum line? And is it a formed hose? where does it end, by what part of the engine?
Steve
Old 06-29-2005, 08:43 AM
is there a way I can call you or you call me?
Old 06-29-2005, 08:51 AM
I can also take a picture and e-mail it to you the hose is black it has the plastic heat sheild attached to it it is routed from the battery area and has rosebuds around the fender and then goes to the back of the engine
Old 06-29-2005, 09:33 AM
1931 steve's Avatar
Wiki Edits: 4
Send me a PM with you phone # and I will call you.
Steve
Old 06-29-2005, 10:04 AM
I just spent the last 30 min looking for the hose and where to put it and found out where it goes there is a small connection by the back side of the motor I should be a master tech lmao Thanks for all your help Ken
Old 06-29-2005, 10:40 AM
1931 steve's Avatar
Wiki Edits: 4
Good job !!!!!
Steve
Pro Topline Heads surfinca Engine 33 12-28-2008 11:37 AM
68 Chevy Impala or Honda Civic rpierce77 Introduce Yourself 5 01-08-2007 08:27 PM
Hottest car in L.A. is a 69 Impala?? bullheimer Hotrodders' Lounge 28 05-08-2006 07:11 PM
2000 Impala Biggin260 Interior 1 06-28-2005 02:06 PM
66 Impala 530 HP SBC black66 Introduce Yourself 1 10-12-2004 02:04 AM
