2000 impala where is tach wire? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2010, 04:11 PM
I dont have a wiring diagram for my car, but I was wondering where is the tach signal wire on my 2000 chevy impala. It has the 3.8 V6 engine. I want to install a tachometer on my dash... any help would be appreciated....!!!!!
Old 01-23-2010, 04:51 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If it's a aftermarket tach you should be able to go to the coil for it to work just like old school cars.JMO If you were changing out the entire cluster then you go to the PCM.
Cole
Old 01-23-2010, 06:16 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cole
I believe that year engine is a coil pack with crank sensor = no distributor.
I wonder how that works for an aftermarket tach?
Old 01-23-2010, 06:28 PM
I want to install an aftermarket tach
I want to install an aftermarket tach. I believe this engine has no distributor and has a coil pack. So I need to find the tach signal wire I believe thats in the wiring harness? Im not sure.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
how to wire a sun super tach teds 46 Electrical 4 11-06-2011 01:56 AM
Cruise Control Compatibility with LED's? cboy Electrical 44 10-01-2010 12:08 PM
Tach cool rockin daddy Electrical 3 09-22-2006 04:12 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 07:28 PM
