2000 k1500 5.3L solid axle swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2011, 07:16 PM
i just bought a 2000 chevy half ton with a solid axle swap. i was told the axles are from a 1979 one ton ford and that they were dana 60 rear and 44 up front. i was wondering if there was anyway to tell exactly what axles they are and what year they came from. idk if it helps at all but it is disk breaks front and rear.
thanks ahead of time
Old 11-19-2011, 07:25 PM
Wiki Edits: 31
Dana Ford axles from a '78-'79 are the desirable swap, disc brake kits are common for the rears and would have come stock on the front. you can cross the cover patterns to make sure it is what you thought you bought.
Old 11-19-2011, 07:30 PM
thanks
might be a dumb question but why are the the choice to use in a swap?
Old 11-19-2011, 09:04 PM
Wiki Edits: 31
The front should be a Dana 60 just like the rear, but a '77.5-'79 F250 and 350 will have a Dana 60 high pinion, or reverse spiral cut. it's stronger than others.
Old 11-20-2011, 10:13 AM
so how do i tell exactly what i have?
Old 11-20-2011, 04:01 PM
Wiki Edits: 31
match the differential cover gaskets up.
Old 11-20-2011, 04:13 PM
poncho62's Avatar
Wiki Edits: 5
This might help
Differential Chart
2000 chevy k1500 5.3L v8 MORE POWER musclecarsrock68 Hotrodding Basics 20 11-20-2011 06:12 PM
2000 5.3L k1500 cam choice musclecarsrock68 Engine 3 11-20-2011 12:09 PM
chevy 1950 3/4 ton to 1/2 ton solid axle swap 3/4ton flathead Suspension - Brakes - Steering 5 02-20-2011 07:58 PM
2000 K1500 T-Case questions TRLBLAZR60 Transmission - Rearend 1 03-20-2008 01:01 AM
4x4 axle conversion ttb to solid front axle. Jared Transmission - Rearend 6 11-07-2005 08:50 PM
