2000 lincoln continental - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2012, 04:32 PM
About 2000 miles ago, after a complete service... oil change/check fluids at a local fast lube place, I drove to NYC and broke down, cause low 4 quarts transmission fluid, it was added and car ran great until now, last night started car and it was cold out, didn't warm it up, drove about 2 miles and didn't seem to want to shift, acted same as it did in NYC, only 20 miles per hour and seemed not to shift, pulled over and stopped. Tried to go again and it would not move, today checked trans fluid and is full.. Hope someone has an answer
Old 01-29-2012, 04:54 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Look in the cooling system for your tranny fluid. If the coolant looks OK crawl under and look for a leak.
Is the Check engine light on? that may help steer you in the direction of your trouble.
Old 01-29-2012, 08:26 PM
2000 lincoln
Thanks, but no check engine light or leaks.
2000 lincoln continental tranny problem bobalou Transmission - Rearend 1 12-24-2011 10:01 PM
2000 Lincoln Continental trans shift problems mbooom1 Transmission - Rearend 1 11-28-2008 04:19 PM
69 lincoln continental kennyj Body - Exterior 4 01-09-2007 04:00 PM
1964 lincoln continental robhensley Body - Exterior 1 11-02-2005 03:39 AM
69 lincoln continental GoodoleQ Introduce Yourself 1 07-31-2004 09:29 PM
