2000 lincoln towncar engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 09-11-2012, 12:29 PM
wulf's Avatar
i`ve been asked by a friend to replace the engine in a 2000 towncar(4.6) which he has destroyed by running without oil ! he has bought a 1996 towncar engine to go in as he has been assured it`s the same !! does anyone have any thoughts ? what will need swapping off the old engine onto this to enable it to run ?
Old 09-11-2012, 04:27 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
They're not identical, the 96 has a more restricted set of heads and intake with smaller cams. The valve covers may have different bolt patterns. Other than these minor things the engines should interchange with little if any issues, and the stock ECM from the 2000 should control it without issue.
Your friend might want to hold on to his intake plenum, throttle body and intake air tract for the swap. The 96 engine might not be from a town car (the 96 engines all were identical no matter what they were going in or what they were rated at from the intake manifold down) and these items on the 96 engine may not swap over depending on exactly what vehicle it came from.
EDIT: I just checked and the base model Towncars from 2000 held on to the old NPI 2v engine a lot longer than I thought. Your car's engine may be identical to the 96, as long as it wasn't a Cartier or Touring Edition.
The Following User Says Thank You to Valkyrie5.7 For This Useful Post:
wulf (09-12-2012)
Old 10-14-2012, 05:13 AM
wulf's Avatar
it was pretty straight forward in the end ! had to swap front cover as well as intake manifold but now running sweet as !! thanks
Recent Modern Electronic Engines posts with photos
2000-2006 Lincoln LS irs swap Mutt's37Buick Suspension - Brakes - Steering 2 08-02-2011 08:38 AM
1996 Lincoln Towncar Brake Light/Blinker problems wherenext Electrical 3 05-01-2011 07:09 AM
1996 Lincoln Towncar Flasher/Blinker Issue fredbaker Electrical 13 04-29-2010 05:46 PM
Anyone have a 90s Lincoln Towncar???? sizemoremk Engine 0 09-05-2003 11:06 AM
blend door on lincoln towncar 1991 mohdsal Engine 2 12-17-2002 11:40 AM
