2000 mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2012, 06:27 PM
2000 mustang
hi I'm putting a 350 Chevy engine in a 2000 mustang body wondering if I can control it with ford ecm
Old 08-24-2012, 07:32 PM
LATECH's Avatar
Probably. But It could get to be pretty complicated. Depending on what type of system you run, throttle body,or port injected, and if port- sequential or batch fire,then you probably would need a custom tune to get all the fuel and timing algorythms close enough to run right.
Not to mention the firing order differences to reconfigure the wiring for the injectors, differences in sensors , sensor values,etc. Also, the difference in the camshaft position would be a problem yo overcome. On the FORD HO system(sequential) the distributor uses a narrow tooth on the cylinder #3 blade in the dizzy. The ECM sees that and uses that to sync the cam position signal (generated in the ECM with the signal off the narrow blade)to determine which injector to fire in the sequence (keeping in mind it sprays on the intake stroke and needs to know cam posistion to fire the correct injector at the correct time)
If you are thinking of a newer coil on plug system , well ...add more complications.
But yeah, you could.
Fact is stranger than Fiction
Old 08-24-2012, 07:39 PM
save the coin and buy a stand alone you'll have more money spent trying to configure the stock ford ecm than its worth
Old 08-24-2012, 10:52 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
fun
Also, you can self-flagellate.
vicrod
Old 08-25-2012, 09:23 AM
2000 mustang
How about the Chevy ecm and wiring could it be used in the mustang body.thanks for the replies to my other guestion was a lots of help thank yaw.
Old 08-25-2012, 09:28 AM
2000 mustang
2000 ford mustang Tilden Electrical 1 03-06-2012 03:45 AM
2000 Mustang GT Supercharge ImYourAngel25 Introduce Yourself 1 04-19-2006 04:49 PM
2000 Mustang GT Supercharge ImYourAngel25 Engine 0 04-19-2006 01:51 PM
2000 Mustang GT Supercharge ImYourAngel25 Engine 1 09-29-2005 09:40 PM
2000 mustang gt pernicus Hotrodding Basics 8 10-31-2003 12:14 PM
