2000 PPM Wire - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 06-24-2012, 02:13 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
2000 PPM Wire
How can I verify that I have found the correct wire to hook up to my cruise control system?
I have a TPI ECM 7730 and everywhere I've checked says to use pin C1, red wire.
I like to test things before I go hooking them up to make sure I'm not gonna fry anything.
I tried a test light with the wheels off the ground in drive thinking the light might pulse on and off but I know I'm way off track there as nothing happened.
Old 06-24-2012, 05:33 PM
LATECH's Avatar
Well pugsy, the only safe way to test it is with an oscilliscope, or a logic tester that has an internal resistance of 1 megohm or higher.
You can check it with a DVOM if it is a 1 megohm or greater internal resistance, just use the frequency setting, or the lowest voltage setting , like 100 millivolt, the crank the wheels and watch it.
A test light is a big no on computerized circuitry so use it at the dart game tonight.
I take it that the cruise is requiring a speed sensor circuit that hands it a frequncy somewhere between 0 and 20,000 cycle per minute?(relevant to speed of course)
Is it a factory or aftermarket cruise?
Fact is stranger than Fiction
Old 06-24-2012, 06:59 PM
123pugsy's Avatar
Wiki Edits: 29
Factory TPI ECM and cruise control unit.
I guess relying on the pinout info I found will have to do.
It turned up more than once so I'll assume its accurate.
I read somewhere that it has a voltage of .60 to 13.9.
Can it have a varying output voltage readable vith a DVOM depending on vehicle speed?
I hooked up the wire already and didn't see or smell any smoke, the truck still runs, and no engine lites lit up.
Had the vacuum hooked up to the wrong servo port and the truch revved up so high , scared the $#$#$ out of me. I hooked it up to the other port on the servo and its not working. Thought I seen it pull the servo once when I hit SET and then nothing.
Thanks.
Old 06-24-2012, 08:17 PM
LATECH's Avatar
Not sure about the voltage level. I am thinking it wont be high.
speed signals are usually converted in the PCM from a pulse at the VSS they are changed to a frequency that is handed off to the electronic speedo.
The higher the frequency the higher the speed registers.Not so much voltage related.
Chances are you have it hooked up correctly as you checked 2 sources and had the same outcome.
Sure is scary when you get the wrong vacuum supply huh...
The cruise is low speed lockout protected. It wont activate or be reactivated(resume) at speeds below 30 ish miles an hour, for safety reasons.
You wouldnt want to hit resume at the stoplight after making a stop from about 90 MPH.
"Gee officer my cruise control was burning rubber, not me" probably wouldnt work, and it sure wouldnt be safe.
Hope this helps.
Old 06-25-2012, 04:32 AM
123pugsy's Avatar
Wiki Edits: 29
I got it jacked up with the wheels off the ground. I had it in Drive the first time I checked it out. Lucky it didn't fall off the jack at the time or I would have went right thru the garage.
Now I just need to figure out why its not working.
Old 06-26-2012, 06:20 PM
123pugsy's Avatar
Wiki Edits: 29
Figured it out. The brake pedal sags slightly. Got to add a spring to it to keep it all the way up.
Had it jacked up and in Drive again and the engine was revving up and down. I figured w/o the load might be causing it so I set it down and went for a drive.
Works perfectly.
Thanks,
Pugsy
Old 06-26-2012, 06:43 PM
LATECH's Avatar
Makes good sense. My dads car would drop the cruise when he hit a hard bump. Come to find out the bump flickered the brake lights on and cut the cruise off.Same thing, add a spring...voila.
Recent Modern Electronic Engines posts with photos
2000 impala where is tach wire? chs1974 Electrical 3 01-23-2010 07:28 PM
wire terminal broke off 2-wire alternator bullheimer Electrical 3 10-11-2009 11:22 AM
Shop Converted My 3-wire Alt to 1-wire -- Should I Be Upset? JohnTN Electrical 2 06-28-2006 07:50 PM
Wire Diagram for points,starter,1 wire alt,and distributor plainhavoc Electrical 3 04-12-2006 03:13 AM
Help Identifying 2000 GMC Wire Connector Seon Electrical 8 10-24-2004 08:41 AM
