2000 ranger abs issues
Ive been trying to figure out what is causing the abs to kick in briefly at 10 mph
or below. It has a b9399 code showing for brake pressure switch malfunction but that come on right after i installed new rotors and pads. i cleared the code and it hasnt come back. it does still have the intermittent abs coming on at low speed under light braking. Any ideas? |
I dont recall if the sensors and tone rings are captive(enclosed) on that model, if they are, a wheel bearing could be the issue,also an intermittent break in the lead from the sensor is also a possibility.
If the tone rings are exposed, where you can at least see them , clean them of any metal that may be clinging to them and likwise the sensor also. If you can replicate the issue a few times maybe you can get it to trip another code so as to give you a little more to go on. |
| Cramming a V8 into My 2000 Ford Ranger with 3.0L Engine | BlueJacket1992 | Engine | 10 | 08-31-2009 06:18 AM |
| 2000 gmc 4x4 | novakidd 63 | Hotrodding Basics | 4 | 01-28-2007 05:55 PM |
| 2000 ford ranger - no taillights | goose74 | Electrical | 5 | 09-06-2005 08:00 PM |
| 4.3L will not run above 2000 RPM | 2000blazer5speed | Engine | 6 | 06-11-2004 04:54 AM |
| Trailer Towing w/ 2000 Ford Ranger | nightrain_rod | Transmission - Rearend | 17 | 06-25-2003 06:07 PM |
