2000 silverado 5.3 tranny problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2007, 09:01 PM
ricks032003's Avatar
New Member
I have a 2000 silverado 5.3 with a problem of the tranny slips in and out of overdrive while driving at 43-47 mph. Does anyone know what could be the cause? Thanks everyone for any help.
Old 08-09-2007, 09:15 PM
we had a malibu that would shift back and forth around 40-45 maybe thats it.
Shane
Old 08-10-2007, 07:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
mileage on this vehicle and trans?
has the vehicle been scanned with a quality scanner? Need to verify the PCM is commanding this action or if the trans has internal errors/problems.
Could be a TPS worn spot putting faulty info to the PCM ( an example the scan may turn up)
Old 08-10-2007, 07:23 AM
New Member
115,000 mls on motor and trans, original. I will take truck to tranny shop for scan.
Old 08-10-2007, 09:18 AM
It's probably just hunting, an annoying characteristic when it's in the speed range that's almost fast enough for 4th and almost slow enough for 3rd.
Talk to your dealer as GM put out a fix for this.
Bogie
Old 08-10-2007, 09:50 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
This is going to sound out there, but I had a similar type problem (shifting) on a 2000 Yukon (same Motor and Trans)-turned out to be a dirty MAP sensor-(they scanned it, no codes,didn't completely believe me, as it didn't do it all the time-put on a Data logger and sent the results to GM)replaced sensor, end of problem-
Old 08-12-2007, 07:22 PM
New Member
35window, Thanks for the info, I took my truck to a coleman taylor transmission shop, the manager a fellow streetrodder, said he thinks it could be the t.p. sensor (throttle position sensor) which i will replace this week so stay tune.
700R4 Tranny Shift Problem riesman20 Transmission - Rearend 2 10-13-2006 10:21 PM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 05:44 AM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
HELP!!!! Tranny removal problem HotRod63 Transmission - Rearend 2 12-05-2002 09:33 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
