2000 Silverado Code - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2007, 10:48 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
2000 Silverado Code
I got a P1870- Transmission Slipping code from my 2000 Chev Silverado. Am I in trouble with this thing?
Pugsy
Old 05-15-2007, 06:05 PM
airworld2's Avatar
4l60e
1870 component slippage, most case this is set from no lock up, valve body issue...
airworld2
Old 05-15-2007, 07:24 PM
sound like probably the torque converter clutch (TCC) or one of the pistons within the valve body of the transmission.
Old 05-16-2007, 04:30 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks for the replies. What can a backyard mechanic like myself do to check this out. I have rebuilt a TH350 recently,so I know a few basic how-to's.
What model tranny would be in this truck? Its 2WD behind a 4.3 Liter 6 cylinder.
Also,some time ago the TOW/HAUL button on the gear shifter stopped working. Could it be related?
Thanks,
Pugsy
Old 05-17-2007, 05:44 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
I've found out its a 4L60-E tranny.
Any tips on diagnosing the exact problem?
Old 05-17-2007, 06:16 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
mileage on the trans?
1870 code is usually a slipping converter clutch related , not always.
A rebuild on the v-body or a TransGo repair kit for the PWM lock-up circuit of the v-body will fix that.
BUT , IF the converter clutch lining is burned / worn out.... the converter must be replaced too.
You need a properly experienced tranny shop / person to help you.
Old 05-18-2007, 03:32 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
It has approximately 85,000 miles.I've had nothing but bad luck using "properly experienced" tranny shops and I like to learn more and not be held victim to every shop that tells me it needs a full rebuild for any symptom I describe. Sorry, not all shops are like that but I don't know of an honest/good tranny shop in my area.
Pugsy
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
2000 Jimmy with shifting problem (code P0753) rjdrw Transmission - Rearend 4 12-27-2006 05:47 AM
2000 Silverado 5.3 Check Engine Light Chevy_SS10 Engine 1 04-18-2005 10:39 PM
Poor Quality of 2000 silverado transmisison gchandler Transmission - Rearend 13 10-10-2004 06:50 PM
2000 Silverado P0440 emissions evap code Chevy_SS10 Engine 2 08-08-2004 09:32 PM
