Thread Tools Search this Thread share on Facebook
  #1
Old 12-29-2011, 09:54 AM
ghost1 ghost1 is offline
2000 Suburban 4L60E problem
Just rebuilt the 4L60E because I had lost 3rd and 4th gears.
Air checked as I put it all together and everything checked out. Once I installed the trans., and test drove all I have is reverse and 1st gear.
I cannot get it to shift even mannually.
I pulled the wire harness off but it made no differance I still only get reverse and 1st.
Can anyone tell me where I might have missed something?
Register now (free) or login to remove ads
Old 12-29-2011, 07:34 PM
joshp83's Avatar
joshp83 joshp83 is offline
owner of Prices Garage
are u sure its first and not taking off and staying in 2nd if if the sprag is in backwards or locked up or the clutches are to tight
Old 12-31-2011, 10:30 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1,659
You missed something. When the wire harness is unplugged the trans will default to 3rd gear in "D" if the trans is built correctly.
Reverse is a function of the manual shift valve, not solenoid activated
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "2000 Suburban 4L60E problem"
ThreadThread StarterForumRepliesLast Post
1994 Chevy Suburban K1500 4L60e Transmission Problemrmar2010Transmission - Rearend211-29-2010 03:08 PM
2000 4L60E to an earlier 4L60E, What do I need to change outaquaterrarvTransmission - Rearend204-08-2010 06:22 PM
2000 Tahoe W/4L60E trans problemcrackrbaby1Transmission - Rearend004-21-2009 08:12 PM
4l60e problem 93 suburbanhecfrombxTransmission - Rearend2104-04-2009 07:40 AM
96 Suburban W/4L60EBICHN69Transmission - Rearend205-24-2005 10:43 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
