2000 vette problems-need a wiring diagram
Not a very good mechanic but a worse electrician.
Got a 2000 with no windshield wipers, no rear taillights, and now starting to overheat but can't tell when.
Car repainted recently so has been apart some but was always running.
The windshield wipers have a good fuse. Far as I've gotten. I need a wiring diagram. I bought one of those DVD manuals but I can't get the dang thing to work on Vista.
Haven't done much more with the taillights. I know where to crawl under to check but thought I'd try to do it post diagram.
The reason to post here about the overheating is I don't think the fan is coming on properly for one. But it is coming on some. It won't run for very long after cutting the car off even though the engine is hot. I don't think that is right.
Also the car has a driver side only hvac climate control system. At times the outside temp reads -32*F, others normal, and others goes up and down. The AC on when working definitely causes the car to run hot sometimes but not consistently. At times the AC and the engine is running fine. I don't see a repeated pattern except that it does seem to run hot more often when the AC is running. (The water pump is working and I've got plenty of fluid in the radiator).
I need a diagram to figure out where the outside sensor is to keep the AC on and I wonder how it relates to the engine fans. The high engine temps should override the climate control and the fans. I don't even know if they are remotely related.
And if someone knows all the answers I'm not adverse to being spoon fed the answers to correct this stuff.
Thanks all. Looks like a great forum.
