2000 vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 09:30 AM
2000 vortec
motor loses prime after 1 to 3 hours of sitting.crank motor all u want,will not fire unless its givin a shot of starting fluid.yes,pump does come on when ignition is turned on.55psi of fuel pressure before cranking.
Old 02-20-2012, 05:55 PM
LATECH's Avatar
Most likely cause is poppet injectors are not opening as they should.
Your fuel pressure should be a little higher as the pump runs but 55 is the lower limit.
55 on your gauge, given the percentile for error of a few percent, could still be a few pounds light pressure wise.
Pretty tough call there,what is the pressure with the engine running?
Old 02-20-2012, 07:33 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Over the years, I have found vortecs to be extraordinarily sensitive to fuel pressure. I have seen many that test at 55 psi, but will not start without "help". If your guage is 2-3 psi high, you now have 52 psi, and it will definately not start. My first bet would be to change the fuel filter, and retest. Then do a running pressure/volume check. Please post the results, and it will help narrow the possibilities.
Vortec 5700 from 2000 Escalde rebuild jganderson Engine 19 06-20-2010 02:08 PM
im converting a 96 350 vortec and putting in a 99 454 vortec rkoontz93 Introduce Yourself 1 05-11-2010 03:26 PM
1999 or 2000 350 chevy vortec motor help!! QUAKE_WARS Engine 3 06-03-2009 07:58 PM
1999-2000 Cadillac Escalade 5.7 Vortec Motor?? acr Engine 5 08-04-2005 05:12 AM
2000 Vortec Swap - Engine Won't Run - Vats? Adam Mclaughlin Electrical 3 03-22-2004 08:52 AM
