2000 Winstar transmission issue - Again - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2010, 01:14 PM
el pollo's Avatar
It's shady under this tree...
Hey all,
I'm in need of some help yet again. My wife's 2000 Windstar lost the transmission a while back, and now that I have the cash in hand for a rebuild, I have been chipping away as time permits to remove the transmission. I am essentially ready to drop the transmission, yet I am having a difficult time finding a way to brace the engine. I am using an engine hoist with a leveler with some chains. I was thinking of using the exhaust manifolds to wrap the chains around, but I am doubtful that they can hold the weight. I am also noticing that wrapping the chains around the exhaust closes to the firewall will be a major project in it's self. Is there anything I should be seeing that I am not when it comes to bracing the engine? Or do I not have to remove the subframe at all, and only minimal effort is needed to brace the engine?
All I know is I am too far into the project to back out. And if I ever have to do this again with a FWD Ford, I will send it to the crusher.
Pro Topline Heads surfinca Engine 33 12-28-2008 11:37 AM
1991 Chevy Truck transmission seal leak D0UG Transmission - Rearend 5 08-01-2008 07:59 PM
Ford C4 Transmission shift positions RAW Transmission - Rearend 6 11-29-2006 10:18 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
tricks for motor/transmission alignment? killerformula Engine 24 07-03-2004 01:00 AM
