2001 aztek brake pedal issue after blown wheel cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2010, 08:12 PM
fast68's Avatar
likes chevy trucks & boobies
2001 aztek had blown wheel cylinder
replaced it and bled both rears.
cant get pedal to be firm and have decent brakes like it should have
bleeding and bleeding and no air coming out
any ideas?
truck sat for a couple years parked not touched due to blown up enigne in which we replaced recently.
do i have to do something with the ABS maybe?
thanks for anything
Old 10-06-2010, 08:23 PM
LATECH's Avatar
The gm procedure (after what you have done allready) is to perform an automated bleed. You will need a scanner.
The service procedure says to do an automated bleed if a manual bleed does not produce satisfacory results
Perform automated bleed when replacing Brake Pressure Modulator Valve
Perform automated bleed if extreme loss of brake fluid has occured (air ingestion)
Rock Hard Brake Pedal 64nova Suspension - Brakes - Steering 9 11-16-2006 03:34 PM
new master cylinder, bleed still no brake! customdrumfinishes Suspension - Brakes - Steering 11 11-05-2006 07:07 PM
No consistent brake pedal risaacp Suspension - Brakes - Steering 15 10-21-2006 06:46 PM
Brake pedal Clunk montea Suspension - Brakes - Steering 3 05-19-2004 08:34 PM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 03:38 PM
