Thread Tools Search this Thread share on Facebook
  #1
Old 01-29-2012, 11:57 AM
2001deville 2001deville is offline
2001 cadilac deville with leaking head gasket
Hello,
I am the owner of an '01 DeVille with a leaky head gasket. I checked the internet and have seen products ranging from $10 to >$250. does anyone have any experience with these products working and also clogging the radiator and heater core?
Thanks
Register now (free) or login to remove ads
Old 01-29-2012, 12:18 PM
Irelands child Irelands child is online now
The only REAL fix is a new head gasket. The products you are looking at might be a band aid for a few hours/days/weeks, but you will end up with a new head gasket or a dead car
Old 01-29-2012, 02:27 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Originally Posted by 2001deville
Hello,
Thanks
I dont believe in cure in a can. I have heard good things about a product called Kseal. I have never used it.
Chet
Old 01-29-2012, 02:38 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: Tips
The product K seal does work, But IIRC it says dont use on northstars.
Anyway, the gasket didnt fail, the head bolts are pulling the threads out of the block, causing a head gasket to fail. The right and only way(IMHO) to fix this is to take off the heads , helicoil the block as The GM tech bulletins instruct and re assemble.
this is one of those times that mechanic in a can will just be a disaster.
I have put K seal in an old raggedy @** Cavalier with a 2.2 and in less than 5 minutes it sealed the leak, The car was not worth the time to fix it, nor would the price of parts justify it.
A car like a Cadillac in nice shape,it should be fixed correctly the first time.
Old 01-29-2012, 03:37 PM
Northstar T Northstar T is offline
latech knows of what he speaks. he's right on the money on this one, and I've done more than a few Northstars. Not an easy job to pull that caddy motor out and do ALL the head bolt threads, but that's the only way to do it.
Russ
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "2001 cadilac deville with leaking head gasket"
ThreadThread StarterForumRepliesLast Post
2001 cadillac deville 4T80E problemssp_18902Transmission - Rearend201-27-2012 06:19 AM
2001 struts leaking oil into hood insulationfast68Suspension - Brakes - Steering111-12-2009 11:29 AM
cadilac deville overheatingwulfEngine908-26-2009 12:47 PM
leaking head gasket?Festive57Engine1110-17-2007 11:03 AM
New head gasket leaking.What did I do wrongBuffedEngine308-27-2005 07:57 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
