Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2001 cadillac deville 4T80E problems
Old 01-27-2012, 06:19 AM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by sp_18902
I am working on my 2001 cadillac deville. I had a tcc problem. I replaced the tcc and the harness. everything worked out good. I had a leak in the side pan so i tore it back down and replaced the gasket. Then added 5 quarts of fluid and started the car. I noticed it pushed some fluid out the filler hole and then it would not go into gear, nor would it take fluid. I found the pump shaft twisted and broken. I have gotten another one but would like to know what caused this. If anyone could advise me on this i would appreciate it. I don't have alot of experience with automatic trannys. The transmission is a 4t80e.
you put the studded bolt for the trans mount bracket in backwards. short end goes into the casting, not the long side. i did this once...
