2001 cadillac deville 4T80E problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 09:57 AM
I am working on my 2001 cadillac deville. I had a tcc problem. I replaced the tcc and the harness. everything worked out good. I had a leak in the side pan so i tore it back down and replaced the gasket. Then added 5 quarts of fluid and started the car. I noticed it pushed some fluid out the filler hole and then it would not go into gear, nor would it take fluid. I found the pump shaft twisted and broken. I have gotten another one but would like to know what caused this. If anyone could advise me on this i would appreciate it. I don't have alot of experience with automatic trannys. The transmission is a 4t80e.
Old 01-26-2012, 02:52 PM
Crosley's Avatar
Wiki Edits: 1659
sp_18902 , Welcome to Hotrodders.com. I edited the thread title to provide vehicle information in the subject.
Since you changed the torque converter and then developed a damaged input driving shaft to the pump, I would speculate that you did not have the torque converter properly installed when the trans was bolted back to the engine.
The pump may be damaged too.
Old 01-27-2012, 06:19 AM
tnsmith10's Avatar
when will it rain???
you put the studded bolt for the trans mount bracket in backwards. short end goes into the casting, not the long side. i did this once...
Cadillac 4T80E Transmission helvehammer Transmission - Rearend 1 01-20-2012 05:13 AM
4t80e Cadillac Trans Problem mike0969 Transmission - Rearend 1 05-21-2010 10:35 PM
4t80e Cadillac Transmission Problems? mile-hightoyz Transmission - Rearend 8 05-12-2008 09:15 PM
Cadillac 4T80E Trans Northstar John Transmission - Rearend 2 05-12-2008 09:02 PM
4t80e Cadillac Transmission Problems? will22 Transmission - Rearend 2 05-12-2008 08:24 PM
