2001 chevrolet engine and tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2008, 06:43 PM
hi i recently installed a 2004 5.3 engine out of a 2wd suburban into a 2001 4wd silverado 1500 i also swapped the transmission and had the tailshaft and other opponents changed however it does not want to shift correctly in 4 low do i need to have it reprogrammed? or should i just start looking for a new transmission thank you
Old 11-24-2008, 06:56 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Moving this to the Transmission/rearend forum
75 F-350 engine, tranny swap loosebb Engine 1 09-05-2008 03:10 PM
LS engine question along with a tranny swap HammerGVette Engine 5 08-23-2008 04:00 PM
Engine and tranny Swap in 78 Monte... BRSleeper2 Hotrodding Basics 6 07-08-2008 01:49 PM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 02:21 PM
Tranny and engine swap questions...."1990 caprice classic"th400 vs 67' muncie 4 speed 74chevyflat Engine 5 02-10-2007 10:28 PM
