2001 Dodge Ram "hood" - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2013, 06:02 PM
My hood is stuck big time closed, I cut the rod but still no release, everything is sooo rusted out anyway. Any ideas? I am about to get a new one (junk yard) any pictures of the complete latch, tia. Dana
Old 05-09-2013, 06:26 PM
Does the cable seem to be hooked something? When you pull on the release does it seem like it's "doing something" and not just loose?
If it seems like it's doing something, have someone pull on it and get out there WHILE it's being pulled and pull up on the hood while pushing it sideways, wiggling it back and forth up down back and forth, sometimes you can get a tight latch loose that way.
The "Rod" would likely only be for the safety latch, not the main latch. Does the hood come up at all? Maybe it's the safety latch that is caught?
You may be able to reach it from below, there is an air deflector under the radiator as I remember and you can remove it gaining access possibly?
Old 05-09-2013, 07:51 PM
This may help. I was going to say just undo the latch by the bolts but searched and went with this one to bring back here.
Hood latch problem - DodgeForum.com
Old 05-10-2013, 08:37 AM
Dodge hood
Took all your advise, I did get it loose, but there is so much rust that the whole thing is pretty piss poor. For now I am using a bungy strap for insurance, I really need a complete locking mechanism, oh well. And again thanks for all the help, Dana
Old 05-10-2013, 09:17 AM
If your safety catch isn't working DO NOT drive with a bungy cord that isn't enough! When air gets under that hood it can make a bungy cord look like a piece of bubble gum, do NOT drive with just a bungy cord holding the hood down!
Oil up the latch, pour oil over it, click it shut with a screw driver and pop it open, do this over and over and over and you should be able to get it loose again. Spray oil into the cable housing too.
2001 dodge ram 1500 v6-rough idle rookie builder Engine 15 05-10-2014 06:01 PM
2001 Dodge Ram headlights markadele Electrical 1 01-09-2008 06:56 AM
Hello all... can I be a "Hot Rodder" with a 2001 Z06? Haha Cobra4B Introduce Yourself 4 12-18-2007 11:05 AM
"Mooneyes" Cross Ram Intake and Carburetor 1931 steve Engine 2 03-26-2005 08:00 PM
Carbed "Ram Air Box" KeithB123 Engine 15 03-19-2004 04:00 AM
