2001 Eclipse problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2008, 04:09 PM
I am in the process of purchasing a 2001 mitsubishi eclipse. It is a friend of mine that owns it, and they said the problem is that it is running, but misfiring, and it is getting bad MPG. They checked, and they said that the only problem they see, is the valve cover gasket is leaking oil down on the spark plugs. Would this cause the problem? I am getting the car for $2500. So I think it is well worth it. any advice would be greatly appreciated. thanks!
Old 08-08-2008, 05:33 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Jordan2011,
I would either put new plugs in or clean up what's already in there, including the wires & cap & if it didn't stop missing then I would probably pass on it.
Rich
Old 08-08-2008, 09:30 PM
Check and clean the pcv.
Shane
Trans Question on my 2001 Chevy Silverado albino2_wolf Transmission - Rearend 0 09-16-2007 07:30 PM
BBC stroker problems? rynophilia Engine 2 07-08-2003 04:20 PM
Holley Carb Problems.. Meangreen Engine 8 06-24-2003 08:00 AM
LT1 knocking problems gollygwagen Engine 0 04-23-2003 05:52 AM
What problems should I look for in a 400 sbc? stonedchihuahua Engine 8 11-05-2002 02:36 PM
