2001 Malibu auto trans surges at 30-60 mph almost as if you were riding the clutch?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2011, 12:37 AM
I see where someone else is experiencing the same problem I am having at 127,000 miles. Does anyone know how to resolve??
Old 05-16-2011, 09:18 AM
SSedan64's Avatar
May have better luck with this ?? in the Trans/Rear section.
More Info needed:
Light or heavy throttle?
Which gears? All?
Fluid condition, burnt/smelly,clear red?
Filter/fluid ever changed?
Old 05-16-2011, 09:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
How does it behave if you take it out of OD?
Old 05-16-2011, 07:07 PM
http://www.hotrodders.com/forum/2001-malibu-auto-trans-surges-30-60-mph-almost-if-198
I decided to replace the transmission fluid myself just recently, at 127,000 miles as I have complained about this problem each time I took it to a so called "reliable " transmission shop for a filter and fluid change.
It turns out that the three previous times they charged me for servicing,nothing was done because I found the original gasket on the pan.
What a buncha Crooks.
The fluid was burnt,but no filings. It was kinda dark and thick,but after changing the fluid with a recommended fluid for high mileage vehicles it is now shifting alot better. I saw the thread about using seafoam trans stuff and I just added 1/2 a bottle. I will let it circulate awhile and then change it again. I think it is pressure solenoid journals are clogging. It is fine when it is cold and then acts up after it gets hot.
I haven't yet tried leaving it in third. I will try that next. It does seem to happen only in third gear with light throttle.
Old 05-16-2011, 10:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not siding w/the shops, but the pan gasket will sometimes get reused if it's in good condition. Burnt fluid (not just dark, I'm talking dark and smelly) isn't something that a fluid and filter change will 'cure'- not for long, anyway.
Old 05-17-2011, 06:37 PM
SSedan64's Avatar
Some Shops also install a hose down the Dipstick tube & suction the old fluid out. They can also flush the Trans using the Cooler lines while the Engines running. So maybe they didn't hose you like some shops have others .
A flush isn't usually a good idea as it can cause many problems.
Old 05-17-2011, 08:25 PM
tnovot's Avatar
Do you happen to have a Holley carb? If so, you might want to try a size larger on the primaries.
Terry
2001 Chevy Malibu Tranny issues Malibucdl Transmission - Rearend 6 09-17-2012 03:15 PM
Clutch fight auto trans cwhit1 Transmission - Rearend 4 12-05-2010 04:00 PM
'2001 Malibu temperature sending unit not working lamothe1 Electrical 16 03-14-2007 10:41 AM
Uneve Brake pad wear on 2001 Malibu Malibucdl Suspension - Brakes - Steering 17 04-09-2004 10:13 AM
Clutch flight Auto trans roys63 Transmission - Rearend 4 01-31-2004 12:41 PM
