Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '2001 Malibu temperature sending unit not working
Old 03-12-2007, 04:01 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
KWEL, you may have had a bad cluster ground, common problem that "rights" itself after working on the cluster..Glad to hear it works!
The "S" terminal is for sender..
The "I" terminal is for 12 volts..
The "G" terminal is for ground..
Should you ever need it again, not all are marked or marked on the rear of the gauge not the laminate.
Doc
