Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2001 Malibu transmission surges in drive between 2,000-2,150 with no pedal change.
Old 05-20-2011, 08:06 AM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by Appliance Guy
Yes it is a 4t40e trans.and it has no leaks and it is topped up. .No engine light comes on, or stored codes. It does feel like the clutch is going in and out of engage.I have had the fluid changed twice at a local shop,but when I changed it myself recently at 127,00 miles,I found that it had the original pan gasket,the fluid was thick,dark and burnt,( No filings )which leads me to believe that they never changed it the times that I took it there. What concerns me is how bad is it and can I repair it without having to pull and rebuild it??
the 4t40e comes with a re useable pan gasket, and i have never changed one out on a trans service. if the fluid is already burnt, there is a good possibility that internal damage has already happened inside.
