2001 Mustang Transmission Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2007, 03:47 PM
HELP ME! I JUST PUT A USED ENGINE IN MY 01 4.6L MUSTANG. ITS STARTS UP FINE BUT THE TRANNY WONT GO IN GEAR IT HAS A MANUAL TREMEC 5SPEED. WITH THE CAR ON A LIFT AND RUNNING I CAN GET IT INTO GEAR BUT WHEN I TAKE MY FOOT OFF THE CLUTCH AND GIVE IT GAS IT STARTS TO DIE. WITH THE CAR ON THE GROUND I CANT EVEN GET IT IN ANY GEAR WHILE ITS RUNNING BUT WITH THE ENGINE OFF IT SHIFTS FINE. IF ANYONE COULD HELP I WOULD BE SO GREATFUL
Old 08-27-2007, 03:07 PM
mustang
Now Floyd is this a tranny and engine swap, meaning was the tremec in the car before you did the swap or you also put this tremec in?
You do not have enough clutch release, you stated you can shift it fine with engine off, so the clutch is not releasing enough. Now why is this?
If this is a different trans and engine, there may be different lenth clutch cables.
If this is the same trans and clutch setup, this car should have a self adjusting clutch. So why doesn't it just fix itself? Stay with me Floyd.
It would be possible, in fact plausible, to suspect that during the course of the engine swap, the cable got some slack in it.
This would cause it to go towards the self adjusting mechanism, possibly flipping the ratching device so that the pivot cannot interlock with the ratchet gear.
If this were to happen you could not get enough clutch release.
Now all you have to do is get upside down, under the dash, look for the ratching device and flip it so it can perform it's function. Good luck. I hope this fix it for you.
1988 Mustang electrical problems! please help! Jim69Mustang Electrical 6 02-04-2007 08:51 PM
Transmission fluid problems? Croz Transmission - Rearend 7 12-22-2006 02:37 AM
2001 T-56 transmission Prob.... syclone477 Transmission - Rearend 0 02-28-2006 11:17 PM
1968 Mustang Patch Panel Problems MrJohnnyUtah Body - Exterior 3 06-09-2005 09:40 AM
Mustang transmission MUSTANG 88 Engine 3 09-17-2002 04:22 AM
