2001 Ranger 2.5L low idle speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2011, 11:07 AM
I thought I would check here to see if anyone recognizes this problem. My daily driver 2001 Ranger (2.5L, 2wd, manual) after sitting for about ten days now won't idle (cuts off) and has set no codes--- If you get it warmed up, the idle falls to a useless 400 rpm and after giving it throttle and letting the rpm's slowly drop the "running" quality does not seem good at around 1000 rpm -- It seems rough, but not really a true "miss" -- Truck has 110,000 easy miles and a possibly related issue is that I suspect the oil pressure switch is failing as the oil pressure gauge is occasionally erratic
Any help appreciated!
Old 06-27-2011, 11:13 AM
Wiki Edits: 31
Clean the idle air control. They periodacly need it.
Old 06-27-2011, 11:16 AM
Banned
The oil gauge is bouncing because it is idling too low, clean the IAC as noted and run some fuel system cleaner through it and you shouldn't have any problems.
Old 06-27-2011, 11:33 AM
Wiki Edits: 31
oil gauge on those fords is an idiot light. goes to 1/2 with 6 PSI of oil. failing senders are common but hurt nothing
Old 06-27-2011, 11:14 PM
Thanks for the help! I already expected that the oil pressure "gauge" was really just on idiot light as I could not see any way just suppling a ground would allow a true analogue gauge to work
Old 06-29-2011, 02:35 PM
Just to close this post: I replaced the IAC today ($37, 15 minutes) and my truck now idling just fine ---- THANKS AGAIN for the spot on correct advise!
2001 dodge ram 1500 v6-rough idle rookie builder Engine 15 05-10-2014 07:01 PM
Idle issue - 96 ranger 406 bug Engine 3 03-15-2010 09:26 AM
89 Ranger Idle Problem keezyman Engine 8 03-10-2007 10:23 PM
1983 Ford Ranger won't idle 1957ford General Rodding Tech 3 04-25-2005 09:37 PM
what should my 2001 gmc k2500hd idle at? lostron33 Engine 7 09-19-2004 06:13 PM
