Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2002 4L60E 4wd Suburban Leak at ectension tube
Old 06-02-2012, 03:35 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
the rear of the 4l60e case is open in a 4x4 application. The t-case is sealed at the front.
Often these adapters become warped and not flat where the gasket needs to seal. You can unbolt the adapter from t he back of the 4l60e trans. Flat sand that area on something large enough to bring the surface back to level.
A square cut O-ring seals up the t-case adapter to the 4l60e case
