2002 blazer 4l60e problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2008, 01:13 PM
i have a 2002 blazer with the 4l60e trany. while driving one day it made a loud noise and now it wont move in any gear forward or reverse . can anyone help me out with this problem thanks.
Old 12-16-2008, 01:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Mileage on the trans?
Original unit or recent repair / rebuild?
Sounds like the unit needs to be removed , disassembled for inspection if the vehicle will not move at all in any gear position of the shifter.
Is it full of fluid?
Is the fluid smelly ,like it is burned?
Old 12-17-2008, 07:35 AM
i did a complete rebuild of the trany a year ago and it ran fine until that day. the oil is good . i think it was the sun gear housing that had broke the first time , can't remember it was a while ago.
Old 12-17-2008, 03:27 PM
sounds like the shell to me.
Old 12-18-2008, 05:53 PM
airworld2's Avatar
4l60e
broken pump gear? did you make sure converter spacing correct last time?
check oil flow remove cooler line place in 5 gallon jug or bucket, start engine see what oil comes out if any.also can be torque converter broken tubine hub
airworld2
Old 12-19-2008, 05:04 PM
tnsmith10's Avatar
when will it rain???
is this a 4x4? to me it sounds like it might be transfer case related...
if it was the sunshell, it would still go forward.
Old 12-19-2008, 05:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF the t-case was the problem... and the 4L60E was still working.. then the out put shaft of the 4L60E would be spinning in D or R shifter position .
When you place the transmission 4L60E into PARK .. there should be a ratcheting noise as the park pawl tries to stop the output shaft of the transmission 4L60E
just a random thought
Old 12-26-2008, 12:27 PM
the truck is 4x4 . i took the trany out to inspect and took apart the insides everything looks fine no metal shavings if you turn the input of the transfer case the output and the front spline for the front wheels turn ok which tells me the transfer case is ok. how can you tell if the torqe converter is bad.
Old 12-26-2008, 01:52 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would have the torque converter checked by a shop. You need the proper shafts to insert into the converter to check the internals of the converter.
If the drive hub was broken on the turbine , you need a input shaft to insert into the converter to check that.
Old 12-27-2008, 09:08 AM
with futher inspection i found the pump insides broke , it completey shattered . thanks for all the help guys
Old 12-27-2008, 10:17 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
a broken pump will stop the vehicle quickly.
post back if you find a cause or more troubles inside the transmission.
Old 12-27-2008, 12:26 PM
airworld2's Avatar
4l60e
should have check that first, its the most common.
make sure to check torque converter to flywheel space , you'll find a lot install 1/8 thick washers to shim space.
airworld2
4l60e problems gmc4x41995 Transmission - Rearend 4 05-12-2006 09:14 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 07:47 PM
1990 Full Size Blazer Steering Column problems..tilt boneyard Buick Suspension - Brakes - Steering 5 02-08-2006 10:39 PM
4L60E Shift Problems chianesi Transmission - Rearend 11 01-10-2006 03:16 PM
4L60E from Blazer chianesi Transmission - Rearend 5 01-04-2006 01:05 PM
