Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2002 Chevy Pick-up 4l80E shifts hard after 10 miles of freeway driving.
Old 10-10-2012, 09:48 AM
c65shoebox c65shoebox is offline
I have a 2002 Chevy Pick-up, 2500 6.0 with a 4l80e that shifts hard after about 6-10 miles of freeway driving. The vehicle has a factory transmission temperature gauge and it reads around 125 degrees most of the time. It has been doing this for a 6 months and it does not seem to be heat related summer/winter driving all the same. It will shift hard (especially 1 to 2) until you shut the vehicle off for 30 seconds and then it immediately shifts fine around town until you go back on the freeway for around 15-20 miles of driving. If you shut if off then turn it right back on it will still shift hard, I have to shut the vehicle off, wait at least 30 seconds before it will shift normal. It takes longer the second time during the same day for it to start shifting hard. The first time around 6-10 miles, then the second time it takes 15-20 miles to start shifting hard of freeway use. The check engine light is not on and does not come on during this process.
