Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2002 Chevy Pick-up 4l80E shifts hard after 10 miles of freeway driving.
Old 10-10-2012, 12:33 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Mileage on trans?
It would nice to run a pressure check on the trans during the standard shifts and when shifts turn harsh.
Depending on mileage , I would suspect a worn boost valve or the PCS may be failing hydraulically and that will not show up on a scan tool
