2002 Dodge Caravan starting issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2007, 12:27 PM
I own a 2002 Dodge Caravan. Yesterday it would not turn over. Jump started twice but now that won't even work. Battery had no water in two cells so I filled it up and charged it - showed 13 volts, but still would just "click" not turn over. I replaced the battery and same problem. Still won't even jump start. What else could be the problem?
Old 08-30-2007, 08:26 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
IIRC, I read somewhere those won't start after a flat battery until you reset the codes..Try that first..
BUT before you do...pull the codes and see if any are there..Correct those first..
Also, I believe there is an Ignition cutout switch or Ignition Stop switch that is computer directed, check that for operation and to be sure it is not stuck "off".
Not a Chrysler Guy at all..GM's..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-04-2007, 09:21 AM
got it
Thanks everyone for your replies. I found the problem - with the lead to the positive terminal - fixed it and it runs great!
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
2002 Dodge Stratus R/T P0301 redlightning Engine 2 06-01-2007 11:18 PM
Need Help With A Dodge Caravan Really Fast!! cesar9 Engine 5 06-26-2005 12:26 AM
1990 Dodge Caravan 3.0 SE fuel problem photogoods Engine 1 12-16-2003 06:03 PM
starting issues...battery or starter? 79454 Engine 6 10-25-2003 04:10 PM
