2002 Dodge Truck Door Hinge Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2011, 10:38 PM
So, strong winds sprung my driver door open and now I cannot open it. I just had the door replaced due to a similar situation where the door hit a fence post while in reverse. However, I just dropped my full coverage and would like to know if there is a much cheaper fix than having to replace the door and front fender. My truck is a 2002 Dodge 2500 Cummins 3/4 ton - the older body style from the 1990s. I am hoping there is a way to bend the hinges or jar the door back so it will open.
Old 01-15-2011, 09:46 AM
Here you go "Basics of Basics" Sprung door hinge repair (click here)
Good luck.
1947-54 chevy truck door/cab dent/hinge superdirt General Rodding Tech 4 12-30-2010 10:07 AM
99 Dodge truck shift problem oldred Transmission - Rearend 11 06-30-2010 11:56 PM
37 Dodge trunk hinge help New Bird Body - Exterior 1 08-23-2008 08:14 PM
46 Ford door hinge problem woody51 Body - Exterior 4 09-11-2003 11:03 AM
46 Ford door hinge problem woody51 Electrical 0 09-10-2003 03:42 AM
