2002 F250 help? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 01-27-2013, 06:38 PM
seniormaster's Avatar
2002 F250 help?
working on a 2002 f-250, 4x4 esof doestn work, wont communicate with a scanner, and the glow plug light is on constantly. to make matters worse, all the books from 2001 to 2004 are missing from my dealership.
as a side note thedome lights dont work, and the #303 relay in the cjb clicks constantly.
Old 01-27-2013, 06:58 PM
LATECH's Avatar
No communication could be a bad 4X4 module
Glow plug light on those never coincided with actual operation of the glow plugs, not quite understanding them too well LOL
Dome light relay is mounted on the IP cluster ( IIRC) and can be manipulated by scanner with bi directional controls.
Relay # 303 will be described in the vehicle owners manual , look in the fuses guide, it is listed in the index.I dont know what the # 303 is right off the top of my head.
Fact is stranger than Fiction
Old 01-27-2013, 07:11 PM
i guess i should clarify, NONE of the modules communicate with the scanner. the glow plugs and relay are in good working order(just replaced all the bad ones).
Old 01-27-2013, 07:17 PM
LATECH's Avatar
Have you checked all the fuses in both the underhood and underdash centers?
Sounds like the scanner is the problem. It wont even scan the base PCM?
Recent Modern Electronic Engines posts with photos
C6 F250 4x4 ekacpuc Transmission - Rearend 2 01-03-2011 04:37 AM
the punisher F250 Punisher-F250 Introduce Yourself 1 07-24-2008 05:16 AM
69 f250 JCalhoun Introduce Yourself 3 12-19-2005 11:14 PM
f250 brakes bustchops231 Suspension - Brakes - Steering 1 08-24-2003 07:06 AM
F250 jamielanari Suspension - Brakes - Steering 4 08-01-2003 05:39 PM
